transmission range sensor | Ford Explorer Forums
remmington76
summerville, SC
98 sport
I have replaced the o2 sensors and also did plug and wires. reset the computer and the check engine light came back on. Had autozone read the codes and it said transmission range sensor???? I have no idea where it is or what is wrong with it. Hoping that Ive just unplugged something by accident. I have looked around and cant find anything out of place. I does seem like it cant make up its mind to witch gear to run in while driving. I feel a slight surge between 40-45 mph. Any help is much appreciated.
the trs is mounted on the tranny on the drivers side where the shift linkage goes in to the tranny most trs s are adjustable if you clean it off real well there are 2 marks useually raised lines that when aligned the switch is in neutral how long ago did you reset the computer? has the system completed its obd2 reset cycle do you know exactly what the code is they got at autozone? that could help alot in helping find the problem
