rickpotz
- September 19, 2008
- Utah
- 2000 Sport
Need Troubleshooting Help On 2000 Sport 4.0L cranks but no start!
Currently, I have a no start situation.
My car cranks but doesn't start.
I sprayed starting fluid into to the air chamber and it started and ran for a few seconds.
I changed the fuel filter. No change.
I felt the fuel pump running for a few seconds with the key on.
I replaced this a couple of years ago. The car sat for two years while I was overseas. I have driven it for about 10,000 since the replacement.
I don't have a car to run errands now so I would like to understand how to check each in order to pin point the problem so I don't have to spend a lot of travel time by bicycle or bus.
I don't have a fuel gauge or a way to check codes.
I have read a lot of articles trying to figure out what components could possibly cause my condition. Your posts have been extremely good.
But, what I need is more information on how to test each part and how to know whether it is good or bad.
I will try to list them and my understanding of the parts.
What I would like is some help on how to test them.
1) The fuel pump.
From what I've read, this can be tested with a fuel gauge. The fuel gauge tells me if the fuel pump is providing enough fuel flow. It has to be approximately 50 to 65 psi? And shouldn't drop more than 5 psi in 5 minutes?
Is there a way to test the fuel pump without a pressure gauge?
Can I detach a fuel line, turn the key on without cranking and watch the gas flow? If so, what type of flow rate am I looking for?
I understand that this is a pressurized fuel system. What I don't understand is how that affects the fuel pump.
2) fuel pump relay
According to my book, the fuel pump relay is position 5 in my owners manual.
Most of the relays are the same. I switched #5 with another one. The problem is the same.
I also tested the current with a voltmeter. One connection with the key off had over 12 volts. With the key on, another connection had 12 volts. It stays on and doesn't cut off after a few seconds? My understanding is that it is supposed to cut off? I believe that that the connection is the current coming from the PCM.
3) what are my options for checking codes?
4) PCM- this sends current to the fuel relay to ground the relay so that the fuel pump can pump?
What is the best way to test this? And, what am I looking for?
What tells me if this part is bad?
5) CKP- this sends messages to the PCM on crankshaft speed and position.
What is the best way to test this? And, what I am looking for?
6) cmp- this sends a signal to the PCM telling it where the number 1 cyclinder is. This helps in timing the sequential fuel injection.
7) fuel pressure regulator-- I'm assuming this increases or decreases fuel pressure some how?
8) fuel injectors-- these inject fuel into the engine.
I understand that if the fuel isn't being injected the car can't start.
I believe these are all the components that can cause my no start situation.
I would appreciate all your help.
Thanks,
Rick
1) The fuel pump.
2) fuel pump relay
Thanks,
Rick
