I found this for you on the coil. This is general information.
I think we need to straighten a few things out about your coil here before we keep going....
The coi recieves voltage at all time the ignition switch is in the run posistion. The ground for the coil will pulse in order to make the coil fire. So lets break this down into an understandable order...
1. Voltage is fed to the coil, and the breaker points or transistorized igniton system completes the ground side of the coil.
2. A magnetic field is built inside the coil.
3. As the engine approachs each cylinder's power stroke the ground for the coil is broken, either through breaker points or a transistorized ignition.
4. The field collapses and put the amperage stored in the magnetic feild back into the coil.
5. Enough voltage is built inside the coil that an arc is created between the cap, rotor, and spark plug electrode and the ground of the spark plug.
Convetional point systems used ballast resistors to drop voltage to the points to around 10V. Older transistorized ignition systems still used the ballast resistor. Today's modern ignition systems, DIS systems, and GM's HEI feed a solid 12V-14.4V to the ignition coil/coils.
The ignition system can be devided into 2 parts. The primary and seconday parts.
The primary side of the coil is the lower voltage side. It involves (I'm including most of the parts since the 1930s on) the breaker points, the primary windings of the ignition coil, ignition module, PIP, hall effect, magnetic pick up coilPCM, ECM, crankshaft posistion sensors, and/or camshaft posistion sensors. These parts work in unison to build a EMF (electro motive force) inside the coil. Without this system the secondary system is useless.
The secondary side of the ignition system is the higher voltage components. It includes plug wires, distributor cap, rotor, spark plug wires and spark plugs. These parts use the EMF to jump the gap at the spark plug.
When checking a non-spark issue you should probably start by...
1. Checking for voltage at the ignition coil.
2. Checking that the ground for the coil is being switched properly.
3. Check the coil wire for breaks or an infinite voltage.
4. Check the cap for broken or missing terminals.
5. Check the rotor for broken terminals or damaged terminals.
6. Check the spark plug wires for breaks or infinite voltages.
7. Check the spark plugs for closed gaps, excessive gaps, and a poor ground.
Basically you have no voltage at the coil, so you need to get voltage there. Either you need a new ignition switch, you have broken wires, the fuse is blown or your terminal in your ignition coil harness is broken.
At the moment fix this problem before you worry about the cap and rotor.
__________________
93 Thunderbird 5.0 HO
89 Firebird L03
95 F150 XL
Get ready for the 351 boss build this summer, 4v closed chamber heads, 2.25/1.75 valves, .750 lift, 12.5:1 piistons, wieand tunnel ram, nitrous, I think its gonna roar!
