StevenGene
- June 9, 2013
- Roseville Michigan
- 2006 Explorer XLT
Hey guys it's me again! Well, I have a problem. The other day I was driving my Explorer(2001) and the thing cut right off. Sounded like a loud puff of air then just shut off. So I had it towed home. I let the truck sit for a bit and then tried starting it again. Sounded like a loud pop and some smoke from the back off the engine, near the heat shield. So thought it was an electrical problem. Checked all the fuses,sensors, wire harnesses and everything seemed fine. So today I decided to take off the upper part of the intake manifold, to check my vacuum lines. Found one that was split straight down the center about 7 inches... Crazy right?? Replaced it an still nothing :/. But when I hit the gas you can hear some slight ticking not very loud but there was a little bit. Anyone have any ideas? Or has ever experienced this before?
I should probably say that I haven't had any issues with driving it before this all happened. Also its getting a spark from the Distributor and its also getting fuel.
