kythri
- October 20, 2003
- Lebanon, OR
- 1999 XLT
Can someone point me in the direction of a good troubleshooting process for the PATS system on my '99?
I've been having intermittent fuel issues - specifically, the fuel pump not firing/priming on attempted startup.
I was suspecting the fuel pump going out, but now I'm thinking it might be the PATS ring in the ignition?
I've tried both of my keys. Both factory original. My regular use key (with most of the Explorer's 150K on it) and the other key, which was stored away and not used.
Neither changes the situation.
My last fuel pump troubleshooting attempt is going to be pulling the relay, and putting 12V to the pump at that point, and see if it fires.
If it does, then that would confirm my PATS theory.
Thank you for any help you can provide!
