Creager
- October 11, 2004
- Charlotte, NC
- '92 Sport 4x4
Hey guys i had a question
I am in the middle of tearing down my rear-end and putting in a TrueTrac with 4.56 Gears.
Do i need to do any special modification to the Ring Gear or the Truetrac to be able to install the C-Clips?
I've gotton mixed reviews from different places i called. 4wheel parts said No i dont, while Randy's Ring & pinion said i need to grind down the toe side of the ring gear 3/16in to clear the TrueTrac Cross Pin.
Also can i use longer bolts to get this ring gear to seat on the truetrac? i can get the ring gear on the stock carrier but not on this truetrac, i can get 7 of 10 bolts around the back of the truetrac, but those last 3 bolts just wont catch... ive tried using a vice, a c-frame press to squeeze it on there, its just being a *******!
EDIT: OK so my question has been answered as far as grinding down the ring gear...
Does anyone know a trick to getting the ring gear to seat equally on the TrueTrac? I spent 3 hours on sunday with a buddy and an hour yesterday trying to do just that step... am i doing something wrong?
