S1L1K0N
- September 29, 2007
- Winnipeg, MB, Canada
- 2008 Explorer V6 XLT
The holding power on the balancer to be able to turn the puller bolt is not much. You can likely use the TDC tool, very carefully, don't hurt the tool. Or you could jamb the flexplate teeth like I mentioned, a second person is best, you'll be there again when tightening the crank bolt.
How does the old tensioner feel compared to the new one? My front tensioner was weaker than my new one, and the check valve was in mine already also.
Broken bolts usually come down to patience and very good drill bits to sacrifice. Take your time drilling, making the hole centered and straight is the big key to it, and watch the metal particles.
I couldn't feel the difference between the existing front cam tensioner and the replacement - so I guess that's a good sign.
I'm going to have another go at the balancer shortly, with that out of the way it shouldn't be much to remove the timing cover? I've got all the bolts removed and everything is out of the way of it already.
I'll come back to the bolt once I start re-assembling the engine, I was hoping to have it back on the road by Monday morning
For everybody else that's trying this, patience is key!
