Curtis
- November 15, 2001
- Orlando, FL
- 04 XLT 4x4
Having some warranty work done at the dealer on my 04 XLT 4x4.
They just called and they have the transmission out for a front seal (all covered under my extended warranty)
They said that there was a TSB on this transmission to adjust the pressure inside and thats probably what caused the leak - too much pressure. $140 for the 1.6 hrs to update the computer in the trans to change these pressures. This isn't covered under any warranty.
Has anyone done this? Should I have it done? Anyone know any more information on this TSB?
BTW - I posted about a bump/thump when I stop, and it was suggested it was most likely the slip yolk. Well the dealer said it looks like the rear end had work done before and there are 2 bushings missing allowing the driveshaft to move around and cause the thump that I feel. AND because there are pieces missing, my warranty wont cover it... $330
