eXcali
- January 19, 2009
- Bourbonnais, IL
- 98 Explorer XLT AWD 5.0
Yeah we were brainstorming around that very issue and thinking about how we could position it so it is in fact a cold air intake. I will definentally be heat wrapping the new headers to cut down on heat in the campartment but that can only go so far. I'll think of something...I've already got the stereo, the tires and rims, the exhaust, an "Air Intake", 210 amp alternator, Optima battery...I'm running out of Ideas!
Woah, don't heat wrap the headers. Very bad idea as it will break them down very fast. I've seen wrapped headers crack in just a couple months. It also voids almost all header manufacturers warranty. If your looking for heat reduction, look into headers that have ceramic covers. Also remember most of your engine bay heat comes from the block and radiator, especially when driving the heat from your headers is being pushed out of your engine compartment.
I'd toy with the idea of routing that intake over near the right side of your vehicle. The radiant heat from the block and the radiator is going to increase the temp of that metal the way it's currently routed.
Another trick you could look into for more power is find a larger intake manifold that will fit your engine. I don't know of any off hand, but look for a newer vehicle that uses the same 4.0. When manufactures have to pass emmissions requirements they usually increase the intake manifold size and add stronger injectors to make up for the power loss.
