steventadams
- February 28, 2007
- New Jersey
- 2001 Sport
So I saw that thread that was made a little bit ago about the GT with the twin turbos and it made me think a little. Why exactly do two turbos create higher pressure for the forced induction? I understand pretty much how turbos work so my understanding of physics and pressure must be a little flawed. The two turbos use the exhaust to spin a rotor that powers a compressor. In the twin turbo setup I'm guessing that each turbo has its own bank to use the exhaust from. That means that each turbo has "X" volume of exhaust running through some conduit of diameter "Y". In the single turbo the rotor is spun by the exhaust from both banks , meaning the rotor is spun by "2X" volume of gas through a conduit of diameter "Y". Doesn't that mean the single turbo will have its rotor spinning twice as fast as each rotor in the twin setup because there is more gas running through a conduit of the same size so the velocity is greater? and so the compressors will ultimately deliver the same amount of compressed air to the engine in each setup?
There is a good chance that my thinking is pretty flawed but can someone clarify the idea for me? thanks. and sorry for the long post but i felt you all should be a part of my daily car-related ponderings...
