i just put on a set of clear corners on my explorer and was just thinking how stupif it looks when the blinker is on than the middle lamp does not flash. if you look at the corner lense you will see three bulbs two of the 3157's and another small one in the top corner. is there any way that i can make the small bulb blink with the others. is it as simple as splicing the two wires togethter or not. another question i have is does anyone else run clear bulbs in their clear corners. i ask because when i replaced all my bulbs with those blue ones that turn to clear light the small bulb was alot brighter than the larger bulbs. if anyone found a way to get a better match while still having all clear(white ) colored light not the amber please post.
