SurrealOne
- May 19, 2014
- OC Calif
- 2014 Ford Explorer Sport
I just got my 3-bar map sensor and 160 thermostat. I'm going to install this weekend and I'm looking for any tips I can get I'm sure the 3-bar map sensor is going to be the easy part of the install but I'm not so sure about the thermostat so that is where I'm going to have some problems and questions?
Do I drain the coolant all the way before I start?
Do I put the same coolant back in or replace with new and what is the coolant water mix I should use?
