Upgrading lighting | Page 2 | Ford Explorer Forums
Upgrading lighting
Rock, the only HID conversion kit I have seen is at 4APC.net . The price for the kit is a little steep (approx. $650), they come with bulbs, ballast, and a wiring harness that connects to the stock headlight switch.
[Edited by RytM1 on 08-06-2000 at 09:04 PM]
ok I have answers to THESE questions now :).
Hella 500's use H3 bulbs which can be replaced with PIAA bulbs, but you may want to check your wattage. Some of the Hellas use 55 watt bulbs and others use 100 watt bulbs. If yours use 55 watts, don't get the PIAA 110 watts bulbs, it can potentially do damage to the casing as well as the wiring, but the PIAA 85 watts would be closer.
Also, if you have a 95-97 Explorer, you can fit the PIAA 1500 or 1400 without any bracketry, in the air dam. You can also buy a bracket (PIAA part #30240). For vehicles that are NOT limited, with this bracket you can fit 940, 960, 910 and 959 lights. If it is limited you can fit 940's and 960's. You have to have the factory fog lights though for these brackets to work, as they use the existing holes in the airdam. For more info on the seperate bulbs you can go to http://www.piaa.com and get more details on the lights!
While we are on the subject of lighting--does PIAA make superwhite backup lamps? I think I saw something about them recently but I can't remember where.
Barry
Tell what type of bulb your backup lights are and I'll tell you if they make one :).
hi matt im posting this for everyone the backup bulbs in 1991-1994 is a #3157
[Edited by jimabena74 on 01-10-2001 at 04:56 PM]
Originally posted by jimabena74
hi matt im posting this for everyone the bacu bulbs in 1991-1994 is a #3157
OK, I apologize but I don't believe PIAA makes a bulb for that.
