UMM IM ALMOST 100% SURE YOU CAN ADJUST CASTER BY, oops caps on, by rotating the camcentric washers unequally, if you adjust the front of the arm out more it'll give you more postive caster by twisting the upper arm back which would angle the ball-joint towards the rear, but if you need more camber on that side also and the caster is maxed you are SOL
I know a few people that have done the 2 piece upper arm flip with spacers and they say it works fine, but i havent layed the arms out to see for myself. Moog still makes the 2 piece upper arm(not sure if it comes with the inside of the two piece arm/bushing part)
