Upper shackle to frame bushings | Ford Explorer Forums
Campoli
Dingmans Ferry PA
2000 XLS
Anyone know where I can get an upper shackl to frame bushing kit?? I can find one for $hit
Cone on someone has to know I can't find nothing online
Daystar makes polyurethane ones
http://daystarweb.com/productdetail.php?productID=38
If you check out either my registry or my restoration link, it'll give some info on easy ways to remove and install them. Quick low down: Use an OTC or other brand u-joint/ball joint press to remove the bushing sleeve, use a 3/8" drill bit to remove the rest of the rubber, sand down the inside, make sure to lube the crap out of the new ones with grease specifically designed for poly bushings (Daystar also sells poly bushing lube) and then use the ball joint press to install the new bushing and sleeve.
Ignore the fact that it says 91-98 only, it'll work on any second gen Explorer as well as first gen Sport Tracs.
Edit: Link to where you can buy: http://www.daystarsuspensionparts.c...ARTNER=gbase&gclid=CI2c3K3ao7cCFeU-MgodaR8Alg
here is the bushing number for ford F57Z 5A546 AA. it comes with the metal sleeve if you happen to screw it up getting the bushing out
That part number for the frame side or the spring side shackle bushing?
just so i dont screw up explaining, or someone doesnt understand me trying to explain it, the bushing that goes inside the red circle
and yes, that is a one off custom shackle made by moi, thank you very much! :D
Awesome thanks guys an yup that's the bushings I need appreciate it everyone
