V6 SOHC...good Seafoam insertion point | Ford Explorer Forums
jordan23
Madison, WI
2001 Explorer Sport 4x4
OK...I've search HUNDREDS of threads and cannot come up with a decent Seafoam insertion point on my 01 Sport. I just installed my MAC Intake...so if one of those hoses coming off of that is a decent insertion point...PLEASE let me know!!
I'd REALLY like to do this today...so if someone could post a pic here for me...that would be GREATLY appreciated!
Jordan23
I don't know where the BB (Brake Booster?) line is...and I've heard that works...could someone PLEASE show me?
J23
I believe the brake booster hose is in the back of the engine compartment, drivers side. It's the hose that runs from the large black drum on the firewall to the back of the engine. But for SeaFoam i run it through the hose on the intake that leads back to the manifold. Of the 2 hoses on the intake its the hard plastic one, not the rubber one
I'm going to try this IAC method too. Definitely seems like an easier method, especially for the mechanically un-inclined (i.e. me).
I've been Seafoamed!
OK, here is yet another Seafoam post. Imagine that.
I was a bit nervous about trying this stuff out, especially with my lack of ability when it comes to working under a hood. Seafoam was so hard to find in Canada, that I never thought I'd ever try it. Then I saw a post recently about how it was available in my hometown finally, so I scored a couple of cans the other day (bilingual labels and all).
Today came the day where I'd have to actually put this stuff in my Ex. I dreaded that moment because of the varying schools of thought on where to insert it. I did a bit of reading up on the "IAC Method" after finding mention of it in this thread. I knew this technique was for me, because I actually understood which hose to use having installed two different air intake systems on my Ex. In fact, having a Volant setup actually made it easier to pour in than would have been the case with my MAC (read on).
Installing the Volant a few months back took way longer than I expected, because instructions were sparse. I finally clued in that I had to cut my IAC hose down an inch or two, insert an "L" adapter, then connect to the intake tube with a short section of hose. All parts were included with the kit, just not instructions on what to do with them. Beauty of this setup is that I simply remove the hose from the intake tube, rotate it 90 degrees, and insert a funnel.
I took my Ex for a short drive to warm it up, then came back. I re-read the instructions, then started the process. As expected she sputtered and ran rough as I poured in the Seafoam. The "Volant IAC Insertion Method" worked like a charm. I finished off the 1/3 can then shut her down. In the mean time, I did the other 1/3, 1/3 thing, put the MAF connector back, followed by the IAC hose and the engine cover. I then waited for a few more minutes (probably 10 minutes in all) to start her up.
My Ex started rough and let out a mini backfire and then the smoke poured. Having read so many people's tales of smoke, I wanted to get out of there so as to not piss off my neighbours. As I tried to back out of my place, traffic was a bit heavier for our street and I had to wait, smoke still pouring. I finally got going and the smoke started to disappear. I did the loop I always do (same one I did to warm up the engine). It includes residential driving, a playground zone and a good stretch of highway speed.
I got back and let her idle in the driveway. I got out and wanted to hear what she sounded like. Definitely a mellower rumble coming out of the Flowmaster. Inside, it felt like the engine wasn't even on. I was skeptical before trying Seafoam because my Ex has been running superb for quite some time, especially with Bama's "Torque" program utilized almost full time. I also had a extensive (and expensive) fuel system treatment done not too long ago and my idle was far from rough.
At the end of the day, even with my Ex running great and not in need of much work, Seafoam definitely made a difference. I had definitely bought into the Seafoam hype , and can firmly say this stuff is as good as you've heard. :thumbsup:
Thanks for the write-up Brad. I really want some now. They got it at Auto Value in Lethbridge at the end of last week so I'm gonna go pick one up tonight:D
Good to see Explorer owners are learning what nearly everyone with a two stroke outboard motor have known for years ... nothing (short of a rebuild) does a better job of decarboning the heads/pistons of a motor than good ol' Seafoam .... I do it every fall to my boat motor before I fog it, flush the lower unit and put it up for the winter .... I usually do my truck too before I drive away from the boat ramp ....
The only problem I ever had was a fouled plug once but they were overdue for a change anyway ... BTW if way any of your neighbors complain about the smoke, just tell them it's for mosquito control ... a buddy of mine had an old Chevy that smoked like crazy and we put a sign on it that said "Scott County Mosquito Control Unit #1"
Sweet:D
Well...I used the "Aldive method" today on my Ex. Poured in about 1/3 of a bottle and Seafoam...it smoked (white) considerably...but not EXCESSIVELY during insertion. Shut er down for about 5-7 minutes then fired it back up. I had very LITTLE smoke at this point. Took it for a ride around the neighbor hood (average speed is about 35 here) on a 5 mile loop.
I must say the engine REALLY appears to be more responsive and--for lack of a better term--cleaner running.
I did notice some people put Seafoam in their gas tanks as well. I still have 2/3 of a bottle or so left...so I was wondering if I should just add it to my tank? Anyone?
J23
LMAO! Read that thread again. Aldive starts by pushing the merits of the "brake booster" method. Billy177 convinces him over several posts to try the "IAC method" because it works for him and works well.
Now it's the "Aldive method"?
Sheesh! It was Billy's posts that convinced me to it through the IAC line.
I've always been sceptical about putting it in my fuel ... either you use enough to do some good and you smoke until you use up the gas or you don't smoke and probably don't have enough to make any difference ... that's in an auto though, I have dumped a half a can in with a gallon of gas (and some two stroke oil of course) for an old boat motor that was loading up as a quick fix .... kinda hard on the fishing environment though and the last few years I do it in a barrel (Neighbors aren't very happy about it but the fish and the DNR are, I'm sure)
Really the key is getting it in there and shutting down the motor before it burns out and then let it soak and losen up that carbon and I don't think it will do that very well mixed down a lot in gasoline .... actually it works better in carburated motors where you can pour it in slowly at first and then dump it and stall the motor ...
Also if you use a lot or have a badly carboned up motor (or shot rings) you should do it just **before** you change the oil, something you don't have to worry about in a two stroke outboard ...
Risolone and Marvel Mystery Oil are basically the same thing and will also decarb a motor although I wouldn't use either in my oil except for a short period to clean out the sludge before an oil change .. all three are solvents but not lubricants and not needed in oil unless you get an auto that was abused by the previous owner ... if you change your oil at recommended intervals there is no need to add any more solvents than are already in most motor oils ... they still make a good decarb which is caused by things out of our control like bad fuel and/or bad fuel storage tanks polluting the fuel
Hehe...I know the "Aldive Method" probably wasn't the correct terminology...sorry for taking the props from Billy177!
Also, thanks for the input Longjohn119!!
J23
