BrentW
- September 1, 2013
- Tulsa, Ok
- 2002 Explorer XLS 4.0 4x4
Ok.. Its starting to get really cold around here and my vents dont seem to blo won the floor. I can pop the glove box out and both of the vacuum pots operate that you can see right there. Both arms move in and out and both are moving their respective plastic arms. I can change the controls from vent to defrost fine but when I change it to floor it doesnt seem like the air coming out down low really changes. There seems to always be a slight amount of air coming out top and bottom. Is there another vacuum pod that I cant see that is maybe not doing what it is suppose to? I like to put the heat on high on the floor when its cold and let the heat rise. When its on vent I at least have heat but the feet get pretty cold. Any help would be appreciated. I did some searching but I cant find this exact issue.
