pj8847
- March 18, 2005
- N.Y.C.
- '95 XLT 4x4 4.0L OHV
OK, Maybe some here can give me a few ideas, because this is a strange one...
My '95 XLT with the OHV 4.0 runs like a top, no problems at all. I noticed though as the cold weather set in and I started using my heat, that when the heater is on, I get great heat, but, the temp gage will fluctuate from the cold point all the way up to the hot line (not the red line, the highest white line, and it hasn't gotten hot enough to trigger the "check gage" light). It will sit fine, but as soon as it starts moving up, it goes up quickly, and sits on the high line for a few seconds, then drops all the way down again just as fast. (small noticeable difference in heat output, but there is a difference).
Now with the heat off, my temp is stable throughout the range and doesn't move from dead center no matter how much load I place on the engine trying to heat it up. ( I can see when the t-stat opens and closes, the gage does move a tiny bit, but not much at all)
I've somewhat ruled out T-stat, since it's obviously working, and the Rad. Cap (it's a new 16lb "lever vent" unit). I have "burped" the system to no end, but there could be some air in there. I do however, notice a very strange occurrence when the heater is on as well.
When the t-stat opens, there is a massive amount of suction in the system that causes the top hose to collapse (top hose is in good shape, but it may need replacement), if I open the radiator cap at this point, I can hear air rushing in, and the coolant level has dropped enough I can add almost half to 3/4 a liter of coolant, but as soon as the t-stat closes, the extra I added in will just come shooting back out of the radiator unless I pop the cap back on quickly. this doesn't happen with the heater off...
I'm not burning coolant, no steam from exhaust. I DID have a small leak from my top hose clamp (cheap ford clamps, get loose after heat cycling and expansion/contraction, allowing coolant to seep past and leak out) but I fixed that, and I don't have any combustion gases getting into the coolant.
So I've ruled out the WP (since it's obviously got circulation) head gaskets and/or cracked heads as well.
I'm stumped, I'm thinking that maybe there is a possibility that the T-stat isn't opening or closing all the way, but why would me using the heater change how anything behaves? I now the heater core is clear, and the valve is actually working. Fan clutch is also working properly.
Would love some opinions on this, because when the gage goes to hot, the RPM's raise until it drops back down, which is as I said, within seconds, So it's not only the gage sensor that sees the temp increase, but the one for the PCM as well. Which rules out faulty sender, bad wiring, etc...
HELP! I've just about checked/done everything I can aside from tearing down the engine to figure this out...
