AwwPhooey
- December 31, 2009
- Sacramento, CA
- '01 XLT
Hello folks, hoping somebody could spare a minute to posit their thoughts on a challenge I’m having.
I have a 2001 XLT 4.0. Original owner ~360K, engine runs like a champ, I take good care of her.
About two months ago started shaking between 65 and 75 mph, seemingly the whole vehicle. It was also drifting a bit to the left, so I took it in and had it aligned and the wheels balanced and rotated. Didn’t change a thing.
Went back to a second shop I trust and had him double check the wheel balance and alignment, and was told everything was spot on and front end is tight. So I figure next step is driveshaft, it’s the original drive shaft with the original U joints.
Got underneath, popped it off and took it to a driveline shop. Had the U joints replaced and the shaft balanced, popped it back in last night. Still no difference. At about 65 to 75 it oscillates pretty noticeably. It’s about eight seconds of oscillation and then it dies down for eight seconds and then ramps up eight seconds more oscillation and then dies for eight seconds, pretty consistently. Whether hitting the gas or coasting.
I’m kind of at my wits end here. Any advice on what more I should consider? The transmission was rebuilt about two years ago from a very good shop (it went 300K before giving out). I really have no other idea on what else to look towards. Pretty frustrated. :/
Any help you folks could offer would be greatly appreciated.
Steve
Steve
