vibration when turning please HELP ASAP!!! | Ford Explorer Forums
yob_yeknom
Moderator Emeritus
Glade Hill, Virginia
'97 XLT & '06 Limited
Sorry if this gets long, but I want to make sure to add in any useful information.
Yesterday my tensioner assembly broke to peices and the belt came off and got ripped to shreds while backing out of my driveaway. I have no idea why that happened. I cut it off and got under the hood and pulled out the broken tensioner pieces and took out the shredded belt. I then cranked it back up and pulled it immediately back into the garage (way too cold to work on it outside). It was VERY hard to steer without power steering. I ordered a new tensioner assembly and got it this morning.
I disconnected the battery and then put the new assembly and a new Gatorback belt on. I put everything back together, reconnected the battery, and cranked it up. I let it sit and run for 5 minutes for the computer to relearn how to idle. Everything seemed to be fine.
When I backed it out of the garage and turned the wheel, I felt and heard a severe vibration. I tried backing up and pulling forward while turning the wheel to see if maybe there was just some air in the power steering system some how. Still it vibrated. I then thought maybe it was somehow in 4wd from disconnecting the battery so I put it in 4wd auto and went back and forth. Still vibration. Then I put it back in 2wd and stuck my head out the window while moving and turning the wheels. I can actually SEE the tire shaking A LOT when turning the wheel.
I have no idea what can be causing this. Could disconnecting the battery have messed up the 4wd system or maybe the ABS system? Could pulling it back into the garage without power steering messed up the rack and pinion?
Please help ASAP since I HAVE to move a bunch of boxes tomorrow and they WILL NOT fit in my car. I don't care if I have to stay up all night to fix it.
I've had to pull two emergency manuevers without power steering, and didn't have this problem when I used the power steering again. That's probably not it. Niether is the battery hypothesis. This might sound kind of dumb, but did you get down there and visually inspect everything? Make sure there are no parts loose or stuck around the wheel, in the suspension, or the drivetrain. Just trying to help, good luck!
Oh, are both tires shaking, or just the driver's side? If it's both, it probably does have something to do with the drivetrain.
Somehow the vibration fixed itself. I let my dad drive it down the road and it quit and hasn't come back. Still curious about what happened, but am very glad it stopped. Really good thing too. It's calling for a foot of snow tonight and I wanna play in it with my big new toy. :-)
this is EXACTLY the problem im having right now...except it only happens in turns.
from other things i've read somehow air is in the steering lines. supposedly it goes away after a day or so.....well i guess we will see tomorrow!
I have had the same tire shudder problem,I could see the tire tremble as i turned the wheel.I fixed it by lifting front wheels off the ground,starting the truck and turning the wheel lock to lock 5-6 times . i could slowly feel and see the tremble go away.Evidently there was an air bubble or something in the line.
