ExcursionMJ
- November 30, 2012
- IN
- 2000 Ford Excursion
Alright so I'm trying to diagnose an issue with my AWD Mountaineer. It's a 2004 with 103,000 miles. When I am driving down the road at anything under 55 mph I do not feel any kind of vibration, but once I hit about 62 I begin to feel the passenger side vibrate. As soon as I hit 65 it becomes much more noticeable and it only gets worse as I go faster. This is not some minor light vibrating in the steering wheel. The whole passenger side vibrates pretty roughly. The best way I can describe it is this way: When you drive down the highway and you hit the rumble strips, it is like that. It's like I'm driving my mountaineer 70 mph down a rumble strip on one side.
I had the tires checked out and two reputable places told me the tires are fine and well balanced. The second place told me that the front passenger side ball joint needs replaced. So I figure I will replace that, but I am told that the ball joint will not cause the vehicle to shake. Now, I am having some issues with the rear differential and I had planned to add some friction modifier and change out the fluid. I also thought about changing the clutch packs. Could this be what is causing the mountaineer to vibrate?
It's a bad vibration. If I put the 3rd row seats up and drive 65 mph the back seats rattle back and forth like crazy. Not lightly, it is very noticeable. Honestly though, I thought for sure it would be some sort of tire issue, and it is not. Does anyone have any leads you could possibly give me? I'd like to get the issue sorted out by the end of the week and definitely by the next two weeks. I'm supposed to take it on a 5 hour one way trip in two weeks.
Edit: A bit more info. I do feel it in the seat, but it's much more pronounced in the passenger side. The passenger side rearview mirror outside vibrates a lot as well once I hit 65 but the inside rear view and driver side rearview don't vibrate. Also again, this is an 2004 All Wheel Drive Mountaineer.
