kristopher_d
- July 26, 2011
- Covington, WA
- '92 Sport 4X4
I've tried all sorts of searches, and haven't found any thing quite similar.
Symptoms:
I'd rather avoid taking the truck to a shop, as I only paid $1000 for it, but I'd also rather it run properly so I can I use it for commutes, towing, and I'd certainly like to hit the trails.
Symptoms:
- When pulling away from stops, the truck will shake violently but smooth out once I'm going more than 5mph (estimated).
- It only happens after driving for a while. I can drive 20 minutes into town without trouble.
- It's worse the longer and faster I've been driving, but again, only when pulling away from stops.
- 1992 4X4 Sport
- Transmission is going (needs to warm up before it'll find a gear, but I can live with that)
- Stock, as far as I can tell.
- U-Joints: I've tried turning, pushing, and pulling on the drive shafts, but the only play I find is at the diffs and t-case, not in the u-joints themselves.
- Hubs: They don't feel overly hot.
- Fluid: Flushed, not oxidized (burned)
- Filter: Changed
