Walk thru of spindle installment | Ford Explorer Forums
thanks...any new parts needed like brake lines, or specialized tools??? doesnt seem to be though...
sweet I got all the tool needed im sure. Just didnt know if anything because of ball joints, i never messed with those
Alright im to not sure I will, looks like I could just bolt it on pretty much and go get a new alignment. But I better check to be safe
Turn your wheels after it is finished and be sure the brake lines don't pull tight. You should be fine. Also, I am not sure the 32mm nut will work since that is for 4x4 and you are looking at a 2wd.
Grab that Camburg kit!
Oh wow, your right Daniel, Guess that isn't needed. Not sure what you'll need for the bearings.
Yeah I tried calling the guy to see if he still had it but I keep getting all circuits busy guy over and over. Its an amazing deal it sells for over 1300 new
Yeah I am running 2wd and over all seems like it will be a pretty easy job except for all the dirt grime and rust that are probably hold those bolts on...guess I will find out lol
