water and KKM | Ford Explorer Forums
water and KKM
thedirtyneck
Blacksburg, Va
91 XLT
hey there, i know that there have been some threads about this but i am looking for soem first hand experiences. Has anyone had problems with their KKM and getting water into the engine. Is it a problem if they get wet?
I had my explorer out in some mud puddles yesterday and i killed the engine by sucking water in through the stock intake box(NOT GOOD). And of course this happened right after i finished making fun or my friends wrangler for having the same problem. Will the KKM help this or is it even easier to get water in with it installed.
thanks
Having an open element filter helps by not creating suction through the stock airscoop. During the AZ run, I was in water above my front bumper without any problems (other than water in my tranny and rearend, oops!) in the intake. I actually have dryer hose ram-air also, but it doesn't create suction. That's the key, not creating suction beyond the filter to suck water up. Also if the filter gets a little wet, it's no biggie like a paper filter. The cotton absorbs some of the water and the filter oil repels the rest.
All in all, an open element filter is a very good investment.
ahhh
ok i see, that makes sense. thanks for the info.
I guess if i leave the bottom half of the stock box in place it wouldnt be a problem either because the suction wont be there. thanks again
dito to what Alec said, sometimes them t-sips know what they are talking about :D
Are you talking about submerging the filter in water or it be able to handles some splashes?
After I go out mud bogging in my Aztek and pulling out stuck Big Dawg GM's with 48" swampers all day, I stop by my neighborhood self-serve car wash and pop open the hood and spray down the engine. I don't bother to cover the KKM filter. It gets plenty wet without killing the engine.
yeah i was just talking about it getting wet, not submerged, maybe mud and water on it though. that answers my question thanks for the info
update from my own experiences
Since i started this post i ordered a KKM and installed it. AND
yes you can get your KKM too wet. i was out yesterday running in some really nice puddles when... you guessed it.... soaked my KKM and killed the engine. I took the intake off and it had muddy water inside that was sucked in through my KKM. i was rather dissapointed considering the 100 bucks i just spent on it, because my stock airbox sucked up water last weekend. I thought that by eliminating the suction through the stock intake sucking up water would not be a problem, however i was wrong. The KKM did last a bit longer than my stock airbox however, but they both sucked up muddy water into my intake, not good.
SO. yes you can get your KKM too wet.
Dirtyneck - Since you have drowned your stock airbox and a KKM filter, it sounds like it's time for you look at getting or building a snorkel system.
You'll probably have to build your own one, I have yet to find a link that shows anyone making a Snorkel for an Explorer.
Here is a link to a webpage where a guy with a Nissan Pathfinder made his own snorkel. You could probably do something similiar.
http://www.pathfinderoffroad.com/tech/snorkel.html
I'm sorry you've had bad experiences with water and your engine. I know how rough that can be. You're probably hitting the water too fast and getting a surge that comes in through and above your grille and drowns the motor. You know how they say a baby can drown in like 2 inches of water? Even though my X can go through water above the bumper, it's all about how I drive through it. The key is to not get surges that rush into the front and drown the filter. Next time you go play, try to be a bit more careful and see how things turn out.
hey thanks for the info, and the links aquaman.
Alec i know i should slow down when going through these puddles but i just cant resist throwing mud all over my truck. thats just so much fun.
thanks again guys
Just another thought.
Make sure you have a shroud on your radiator fan, so that it doesn't propell water at your air filter.
