Fla_15_XLT
- October 19, 2014
- NE Florida
Good God, the Ex have timing chains so there is no timing belt replacement like you see with the imports. Also someone mention a water pump failure that took out valves. NO, the timing belt fails and in zero clearance engines that takes out the engine, not the water pump. Like I previously mentioned the water pump being driven internally by the timing chain more than likely removes much of the torque, and tension on the water pump bearings / seals.
I've had a water pump bearing failure that took out the timing belt - that engine had the water pump driven by the timing belt. Thankfully, that was a non-interference engine - so the result was inconvenience, with very little collateral damage (towing, followed by replacement of timing belt, water pump, tensioner, pulleys). Had it been an interference engine, it would have resulted in bent valves, and possibly piston and bore damage. In this case, there was an indistinct increase in engine noise that lasted a few days at most, with no noticeable coolant loss. The vehicle was a higher-mileage unit, that had evidence of a previous timing belt change - and apparently, the tech had chosen not to replace the water pump or tensioner/pulleys.
Bottom line for this discussion: good engineering and design plans for component failure, and has resilience that seeks to minimize collateral damage when components fail. Ford did a number of things 'right' here - the 'fail safe' programming on overheat is a case in point. The design of the water pump is a pure packaging compromise - they had a requirement to package an engine in a certain max length and chose bore centers that forced them to smush down accessory length. As a consequence, they made a resilience compromise with an enclosed water pump. I would expect that the most of the engines will have a long-enough life, particularly with correct spec coolant. I would also expect they are going to be relatively more vulnerable to catastrophic failure with age and bad coolant chemistry.
Assuming a supplier cost engineer hasn't already driven $.05 cost reduction by using a lesser material quality seals/o-rings or water pump bearings, and created a ticking time bomb. Sadly, all manufacturers make themselves vulnerable to that sort of risk by relentless cost reduction pressures. And we, as consumers, aid and abet that by focusing on the 'shiny toys' rather than robust and resilient mechanicals.
Personally, I'd gladly trade off the $$$$ in electronic add-ons (e.g. MFT nav or forced satellite radio) for more robust and resilient basic vehicle. I've had a real tough time selling that perspective with my wife.
