Water pump replacement. | Ford Explorer Forums
drayborn
97 EB
Need directions on replacing water pump in a 97 EB Explorer. Is this an easy task or should I consult a professional?
What engine
Welcome to this forum! I've moved your thread into the stock 95-01 section. You have to drain the coolant, remove the fan with the fan clutch, then unbolt the water pump. Scrape off the old gasket, and install a new gasket & water pump. Inspect the fan clutch for damage, and reinstall it if it's good along with the fan. Add coolant, and check for leaks.
