atikovi
- September 3, 2002
- Mclean VA
- 2015 PIU
The rear bearings were getting loud in my 2015 PIU so it was time to change them. Getting access and everything else out of the way was pretty straight forward. Wheel off, caliper and bracket off, rotor off, axle nut removed, axle pressed in, four hub bolts removed. That took less than an hour. Next came the bad part of getting the thing out of the knuckle. That took over 4 more hours, and I did have a hub knocker and also used the nut and bolt method. Still have the other side to do. What is the best bearing to put in? Motorcraft? Any other brand not made in China?
