What are pinion and carrier bearings?? | Ford Explorer Forums - Serious Explorations
Mikes95XLT
Bartlett, IL (currently in Bloomington for school)
'95 XLT
Anyone heard of these? Those are new terms to me. The reason I ask is because I have this awful noise coming from my rear end when I'm driving, and when I'm slowing down or coasting between like 15 and 30, there's a really bad groaning noise from the back. So the dealer has it, and told me it's the pinion and carrier bearings, and it's gonna be $1,100 to fix!
So, that's my question. What are these bearings?
That is a whole hell of a lot to fix those. Should cost closer to about $350-400 for parts and labor.
They're basically parts in the rearend that are meant to reduce friction. When they fail you get rubbing parts. The parts are about $100-150, and labor should be the same as a gear swap.
Just to add, if you want to do a gear swap or install a traction aid, this is the time to do it.
Thats a bit extreme a shop that installs gears would proly do it for more like $200 plus parts.The pinion bearing is the bearing on the pinion so it can spin. The Carrier baearings are the two on the carrier so that it can spin....
3 bearings all together ( I think maybe there are 2 on the pinion) Pretty rare that those bearings go out in an 8.8 so you might want a second oppinion too.
A gear install kit for the 8.8 is around $90 this will have all the parts in it needed.
My suggestion is to pick it up from the dealer and tell them where to go. Take it to a 4x4 shop or aywhere that works on rear ends.
This is a Daa 44 but here is where the carier bearings are:
And this is what the pinion bearings look like on the Ford 8.8". You can just see them opposite the pinion gear. My 8.8 rebuild kit cost about $70 from Desert Rat. They installed the gears and locker for $200 labor. I would say you should be spending about $300 tops if all you are replacing are the bearings. If you are regearing, add another $200.
