When the key is cycled, I hear relays click. Would there be voltage at the inertia switch without a functional relay? Also, I removed the relay and jumpered across to rule out the relay. Pump doesn't fire up. Looking at the link you posted it is mentioned the check engine light must illuminate for the pump to work. I'm not ruling it out as a bad pump yet but there is no fuel at the rail.Did the fuel pump relay click at all?
See my edited post aboveNope , you are on it and I asked a bad question.
Ok, I m with yaSee my edited post above
It is a white pin and there is something coating all the pins on the male side, looks slightly white in color as wellNope , you are on it and I asked a bad question.
Next step I guess is to jumper voltage to the pump and see if it runs.
Do I see some heat damage in that connector? One pin sure looks white
Disconnect the inlet line too the fuel filter, and catch the fuel if its coming out. Maybe change it if it has not been done.I put in a new main fuse and it still does the same thing. Crank, no start. I took a look at the power diode. I'm not sure if O'Reilly's has one. I might have to order it offline. After reading about it it definitely sounds like this could be the problem. But with my luck I'm pretty sure it's not going to be. Haha. How would I double check to make sure it's getting gas? I feel like if it's not electrical related it has to be fuel related. If I didn't know any better I would guess it wasn't getting gas. But in this case I hooked the battery up wrong so..
Just mark or tag ,all the connection. You think you'll remember, but you dont. Take pictures. I used beer boxes. As I remove section by section, I uses a different box to hold too the different parts and nuts, bolt, Orings and gasketsYeah, that would be great. I'm located right around the corner from the Phoenix Children's Hospital. I also just recently purchased a crate engine and I'm waiting for that to be delivered. I need to get this to be able to start so I can slap the engine in. I have very little experience in engine swaps and I definitely would be willing to pay for assistance. I have a few friends who can help out
Light works on the dash but there is an issue with the pcm receiving signal from the crankshaft sensor. I'm thinking the square connector at the back of the engine needs to have the contacts cleaned first, then determine what doesn't work.First though, we need a check engine light with key on. That light signifies the pcm is on .
Check engine light is good now. Replaced the crankshaft sensor and the bulb in the dash. Cleaned the harness connectors. Fuel pump is bad, when I push the valve in on the test port at the rail, key cycles on, I got a dribble of fuel out which tells me the pump tried to do something. He is going to cut an access hole in the floor above the gas tank and get a new pump. The motor has an intake valve that doesn't close all the way, can hear compression in the intake, makes it sound like a 2 stroke when running on starting fluid. The dash is now back together, attached are some photos showing the progress.I know it's not my money but a new fuel pump motor just to eliminate it since it's probably old anyway. The check engine light bugs me though.
good on you man, you went way above and beyond to help the guy out.Check engine light is good now. Replaced the crankshaft sensor and the bulb in the dash. Cleaned the harness connectors. Fuel pump is bad, when I push the valve in on the test port at the rail, key cycles on, I got a dribble of fuel out which tells me the pump tried to do something. He is going to cut an access hole in the floor above the gas tank and get a new pump. The motor has an intake valve that doesn't close all the way, can hear compression in the intake, makes it sound like a 2 stroke when running on starting fluid. The dash is now back together, attached are some photos showing the progress.
View attachment 438139 View attachment 438140
