What is required for BL on 94 XLT | Ford Explorer Forums
mdywglr4x4
Macon, Ga
97 Sahara
what other mods besides the BL are required to safely run the Lift on a 1994 XLT...
or can BL just be put on with no other mods???
The search button must be broke again:(
get nice it only a another newbie question
what are you really looking for
mdywglr4x4 what other mods besides the BL are required to safely run the Lift on a 1994 XLT...
You can run the body lift by itself and you can get 31 to fit with minor rubbing.
What else would you like to know?
well....
im talking about things such as Transfer Case, i know with my jeep going up to high means bad vibes... also brake lines... steering parts etc... anything that might be necassary to change once a BL is added??? thank you
A body lift only pushes the body away from the frame. It doesnt affect driveline angles so your t-case shouldnt have a problem. As for other parts, you can get bumper relocation brackets to move your bumpers up. There is also a steering shaft extender to correct the steering bind some people get w/ BLs. These should come with the kit, but check when you order it. Other than that, all you need is some big muds to fill those fender wells :D
Anybody else remember something I forgot?
Ummmm, I have 31/10.50's on my 93 and they don't rub. I can't figure what all the fuss is on lifting and rubbing. I run stock wheels and no susp mods. My Ex has the stock alum. five slanted spoke flat-faced wheels. Why don't my tires rub?:banghead:
OK, I was slightly wrong about suspension mods. I added a set of main leafs on the back, with 3/4 of the eye cut off, under the original mains, and I must say that I am very pleased with the results.:D as for the front no mods on this one.:(
With a 3" body lift are the abs wires long enough to still be used? Can I still keep my abs?
