what the name of this part help please? | Ford Explorer Forums
dkllwdk
clinton, MS
what is the name of the part that goes from the front axle to the frame it look like a idle arm. but it is supporting the front end. 95 ford explorer xlt 4x4 also where can i find a replace part i think this is the part that causing a vibration in my steering.
Help
thanks dave
If it's a couple of feet long and about 1.5" in diameter it's probably the torsion bar. If it is, I doubt that it is causing your vibration. If you can describe your vibration in more detail it will help, like what speed it occurs at, is the vehicle cornering or driving in a straight line, etc.
no that not it, it mount to the frontend and then to the frame on the drive side the vibration feels at low speed and some high had the tire rotate and balance had the upper and lower control arms check out good no problems there. Think it could be a bearing ? no for sureyou can feel the vibration though the steering wheel like some is loose.
