What transfer case chain do I need | Ford Explorer Forums
wes1019
Kimberling City, Mo
97 XLT, 2001 Sport
I just swapped the 4405 transfer case in my 97 4.0 with one out of a 98. How can I find out what chain is in the 98. I swapped the back half of my 97 onto the 98 to get VSS output. Everything works fine except that there is a lot of slack in the chain and I am getting a loud clunk or pop when I put a load on it in 4WD hi or low. I pulled the shift motor and sensor and can feel the chain. There seems to be a lot of slack when compared to the chain that is in the 97. Will the chains interchange. I have found that in sept of 98 they went to a one inch chain. How can I find out what chain is in mine without pulling it and cracking it open again.
Ok the 4405 has three chain options:
HV-070 1.25" Wide with 2 blue link and ET guides 98-Up
HV-051 1.25" Wide with 1 Blue Link 90-97
HV-067 1.00" Wide for Torque On Demand Units (9/98-Up)
It will be difficult to find out without opening, by the year and if its a TOD (Torque on Demand) you can get an answer.
That info is enough to narrow down to the one you need, I know it can be confusing.
I would definitely not interchange them, and most definitely not use the 1 inch one if you don't have a TOD unit.
Hope it helps!
Regards,
Andy Correa
Dear Specialists,
please be so kind and tell me the differences
between the following BW4405 Transfer Case
Chains for the V6 Explorer SOHC
- >97 Morse HV051
98 -> Morse HV070
They seem to be identical, only the blue marks
and the Morse numbers are different.
Kind regards
Wolfgang
