ncyrider
- December 8, 2013
- 2001 Sport Trac 4WD
About to order new wheels for my 01 ST 4x4, the wheels I plan on getting are Pro Comp 15x8 with 3.75 backspacing. So does that mean they will stick out 0.75" (-19mm offset) compared to stock?
For the tires I might get the same kind/size I have now, BF Goodrich 30 x 9.5 R15. Will I need wider tires for the 8" wide rims, or are these ok?
I know this setup should work fine, and my ST has a torsion bar turn...no lift. With the wider stance, the front tires won't rub, correct?
I saw some sport tracs with much wider wheels/tires, so I know I'll be good.. but just wanna make sure before I buy everything.
