Wheel Bearing Races | Ford Explorer - Ford Ranger Forums - Serious Explorations
Wheel Bearing Races
Dickinson, North Dakota
1994 Explorer 4X4 XLT 4DR
Hey everybody, hows it going? I just ordered some wheel bearings for my explorer, 4 timken set37's, two wheel bearing grease seals, and some new caliper slider pins. My rotors that i currently have on are still good, but my question is how do i remove the bearing races from the rotor? Is there two races for each wheel bearing? Thanks :thumbsup:
Join the Elite Explorers $20 Get rid of the ads!
Elite Explorer members see no advertisements, no banner ads, no double underlined links.
. First register on the forum, then join the Elite Explorers to get rid of the ads!
I have the Auto locking hubs, and for grease, i plan on using some high temperature grease that i got from wal-mart.
IAmTodd
4x Explorer Veteran
Johnstown, PA
2015 Jeep
I believe they are pressed into the rotor. You'd have to find a shop that would do it for you if you don't have the press.
There is a race for each bearing. I put on new rotors that came with races installed already.
A guy couldnt just try to beat them out with a hammer? And the same for installing them?
IAmTodd
4x Explorer Veteran
Johnstown, PA
2015 Jeep
The tolerances are very close, you'd be hard pressed(ha!) to get them out with a hammer. You'd also easily damage the new ones going in. Any distortion to the race will kill the bearing.
MrShorty
Spanish Fork, UT
92 XLT and '87 Bronco II
When I did my bearings and races, I thought they tapped out pretty easily. The hardest part was finding and identifying the inside edge of the races where I could tap on them, because of all the grease obscuring my view of things. A hammer and a punch and a few minutes of tapping (probably have to tap around the race in a circle so the race doesn't get crooked inside the rotor and bind up) and the race came right out. Flip the rotor over and tap out the other race. I used a standard bearing/race type tool with the right diameter to tap the new races in. I don't recall having any significant issues replacing the front wheel bearing races.
CodePoet
Indianapolis, Indiana
1993 XLT
Yep, i just put a pipe down the hub, sit it on the race and whack it, then move the pipe to the other side and whack it...rinse lather repeat as necessary.
tweakedlogic
memphis, tn
'92 XLT
It can be done with a punch, cup and hammer. for installing use a bearing cup, large socket, or you can use your old race. Tap as gently as you can to get it to seat all the way in. If you screw up and hit the bearing area of the race, remove it and get a new one.
Jstcruz
Deltona, FL
97 Ex XLT & 84 Ranger
huntman58
Fremont calif.
2013 Dodge Advenger
For over 20 years I have only tapped them in or out as needed with a hammer, socket extension, and an old used bearing race.
For the grease seal I use an old board that is as wide if not wider then the seal and about 1/2 thick to tap it in nice and flat.
cmhaah06
CLOVIS, CA
91 XLT
I know this thread is a little older, but do you remove both races from the front of the rotor, or the back? Or outter through the front and inner through the back?
RobertFord
Amsterdam, Netherlands
1991 Ford Explorer XLT
You tap them out from where they meet, in the middle of the rotor. So the inner race is tapped out from the outside, whilst the outer race is tapped out from the inside. If that makes any sense..
