Yes, you can put Mitsubishi rims on your truck, but you must run spacers up front. Mitsubishi rims have incredible offsets, so if you don't use spacers you'll rub big time. I have seen some Ranger with Eclipse rims, but I can't say I recommend it.
Also check the load rating that is stamped on the inside of the wheel. I suspect that Eclipse rims will be considerably weaker than Ranger and Explorer rims.
