wheel offset for 2007 eddie bauer | Ford Explorer Forums
renzAy34134
Fort Myers Florida
2007 Explorer Eddie Bauer
I have a 07 eddie with 17 inch stock rims. I want to get 24x10inch rims but I need the offset to be perfect or they will rub all over the place. Can anyone help me find the correct offset of my x. THANKS!!!
And what about your TPMS steel straps? Will they fit?
What are TPMS straps? Are you making a funny joke about the lack of tire I am going to have?
Tire Pressure Measuring Sensor = TPMS
These sensors are fastened inside each of your wheels. You need them at your new wheels. On bigger wheels they have to be reprogramed. If they will fit at all.
New one are really expensive.
No one answered this question??
Max offset is 44mm, min is 25mm before it starts messing with your suspension. With 24's you will want to stick closer to 44mm to keep it in the wheel well. I run 25mm on my boss 17" rims and they are right at the edge of the fender flairs.
As for TPMS, the bands suck. If you don't want the light on the dash go and pick up a set of 4 orange electronics stem sensors. They are a direct replacement for the OEM band sensors and quite a bit cheaper.
I believe my 24s on my old 2003 with 295/35/24 tires were +35 or +38 and they fit fine.
I hear my new 2008 may have difficulty with the same setup though?? I thought they'd be the same.
