I need to restate my question. My 02 Sport Trac has 16" wheels. I can get my hands on the identical looking wheels, in 17". Is there any way I can check to see if these will "fit" my truck? The part number is 2 L 24-1007 BC/CC ALSO 2L 24-1007 CD/BD.
Is there anyplace I can look up Ford part numbers on the web ?
But I do not know what offset or backspace I need to look for, if I want to move up to a 17" or 18" wheel. I cannot get a straight answer from any wheel/tire vendor.
Use the same offset as your current wheels unless the 17's are considerably wider. To insure an accurate measurement of your backspacing, lay something accross the the back of the rim, then measure the distance from the mating surface to that point.
