Wheel shaking at 70-75+ mph | Ford Explorer Forums
Aero540T
Holt, MI
2000 Ford Escort ZX2
Hopefully this is the correct forum for this question, but anyways, I've got a 2003 Explorer XLT and whenever I get to freeway speeds, 75+ usually, the steering wheel definitely (and visually) shakes...I'm thinking this could be an alignment problem but I really don't know toooo much about cars at this point.
Any other ideas?
More likely, it is a tire out of balance. I would try having the tires rebalanced first, then taking it to an alignment shop if the tires are balanced and it still shakes.
thanks I'll have a go at that and see how it does
What he said. 90% chance it's a wheel balance issue. Alignment issues tend to make themselves known under braking. Balance issues show up at highway speed and are typically accentuated in a given range like 65-75mph.
SuRrEaLNJ said:
I beleive there was a TSB on a vibration about that speed.
Is this good or bad news for me?
Also my left front wheel seems to be slowly leaking air, my boss (mechanic) says it's because I have aluminum wheels and it's probably corroded around the seal and leaking there...or something like that. It's sweet working where I do, my boss has an antique Ford parts shop where he (used to restore) antique Fords and sells parts and builds engines, etc...it's pretty exciting.
not 100% sure, its kinda a poain for me to get on alldata, but i recall having seen a tsb related to driveline vibration. unfortuneately thats about all the information i have to offer.
Driveline - Vibration/Boom Between 55 and 75 MPH
TSB 05-16-4
08/22/05
DRIVELINE 1ST ORDER VIBRATION/BOOM/DRONE
FORD:
2002-2005 Explorer
LINCOLN:
2003-2005 Aviator
MERCURY:
2002-2005 Mountaineer
This article supersedes TSB 05-3-7 to update the service procedure and to add a vehicle line.
ISSUE
Some 2002-2005 4x4 Explorer 4dr/Mountaineer and 2003-2005 4x4 Aviator vehicles may exhibit a vibration/drone/boom at 55-75 MPH (89-121 km/h). Electronic vibration analyzer (EVA) readings will fall under 1st order rear driveshaft at 2700-3100 shaft RPM (45-52 Hertz).
ACTION
If the condition is present in 3rd gear (with overdrive cancelled), and is isolated to the driveline (not felt through the steering wheel), install a premium balanced driveshaft. Refer to the following Service Procedure.
SERVICE PROCEDURE
NOTE THIS TSB DOES NOT APPLY TO THE SOLID 4X2 DRIVESHAFT, IT ONLY APPLIES TO 4X4 WITH BOOT/SLIP JOINT IN THE MIDDLE OF THE DRIVESHAFT.
1. With the vehicle in NEUTRAL, position it on a hoist. Refer to Workshop Manual Section 100-02.
2. Remove skid plate, if equipped.
3. Remove the driveshaft flange bolts (Figure 1).
4. Remove the transfer case rear output flange bolts (Figure 2).
NOTE THE DRIVESHAFT FLANGE FITS TIGHTLY ON THE AXLE PINION FLANGE PILOT AND THE TRANSFER CASE OUTPUT FLANGE. DO NOT HAMMER ON THE DRIVESHAFT OR ANY OF ITS COMPONENTS TO DISCONNECT THE DRIVESHAFT FLANGES FROM THE MATING FLANGES. PRY ONLY IN THE AREA SHOWN WITH A SUITABLE TOOL, TO DISCONNECT THE DRIVESHAFT FLANGES.
5. Using a suitable tool, disconnect the driveshaft flanges and remove the driveshaft (Figure 3).
6. Measure the NEW driveshaft length from u-joint center to u-joint center. Refer to Step 6a or 6b.
a. Driveshafts measuring LESS than 1194 +/- 1.0 mm must be expanded as follows:
(1) Place driveshaft on a suitable workbench and firmly secure either flange in a suitable vice.
CAUTION CAREFULLY SECURE THE DRIVESHAFT TO AVOID DAMAGE TO THE FLANGE.
(2) Grasp the shaft at the opposing flange with both hands and expand (by pulling) as required to 1194 +/- 1.0 mm.
NOTE DO NOT USE A BAR OR SIMILAR DEVICE BETWEEN THE FLANGE AND CARDON JOINT.
b. Driveshafts measuring GREATER than 1194 +/- 1.0 mm must be compressed as follows:
(2) Grasp the shaft at the opposing flange with both hands and compress (by pushing) together by hand as required to 1194 +/- 1.0 mm.
NOTE DO NOT USE A HAMMER OR SIMILAR DEVICE.
THIS MAY CAUSE DAMAGE TO THE SHAFT FLANGE.
7. To install, align the driveshaft paint markings with companion flange markings, if present.
8. Coat the bolts with Threadlock And Sealer TA-25 meeting Ford specification WSK-M2G351-A5.
NOTE THE DRIVESHAFT FLANGES FITS TIGHTLY ON THE PINION FLANGE PILOTS. TO ENSURE THE DRIVESHAFT FLANGES SEAT SQUARELY ON THE PINION FLANGES, TIGHTEN THE DRIVESHAFT FLANGE BOLTS EVENLY IN ACROSS PATTERN.
9. Support the rear driveshaft.
10. Install flange bolts at rear axle flange by hand.
11. Install flange bolts at transfer case flange by hand.
12. Tighten all driveshaft flange bolts to 76 lb-ft (103 N.m).
13. Reinstall skid plate, if equipped.
Thanks to everyone that helped...I finally had the time to get my tires rotated/balanced and that was the trick thankfully...smooth to 100 so far (didn't take it past that)
LOL I don't think my Explorer could hit 100 unless it was on a long downhill. :D
