hey everyone,
i was told that i grounded my amp to the wrong spot (under the flap piece behind the back seat) where is a better place to ground?
Thats where mine (was) grounded til I sold the explorer.
I had the battery grounded right under the battery, and then the amp was grounded under the flap or whatever like you said, try and get a pic of where it is if you can...
i have a 600 watt sony xplod amp, and it does one quick thump when i start up the explorer, if i turn off all noises i can hear the sub putting out some noise
there is nothing wrong with running another ground wire to the back...But I do more than the least possible for electrical. Wire is cheap...and upgrading grounds does a lot more than 99% of people think.
do you have a fuseblock on the power to the amp if you do check it and if not put one in it will solve the noise had it doing the same crap in my truck was a bad fuse
