While changing ball joints..... | Ford Explorer Forums
KevinK
MD
91 XLT
I'm in the middle of changing ball joints and the right side axle would not come out. The left came out easily, but not the right. Is there a secret to the right side axle?
Thanks in advance,
Kevin
91 XLT
I made a special clamp and did it while it was still on the truck I dont think you can get that side out unless you take the axel apart:(
I thought about that. Unless I get a better idea that is the method I'll try. Was it tough getting the knuckle removed or did you just have to be really careful?
Thanks,
Kevin
I have done three of them the same way and they were all pretty easy it just sucks working under the ex:(
I'm a little worried that I won't be able to remove the nut from the bottom ball joint. Did you use a 24mm socket or closed end wrench for that?
Kevin
I used a socket and a breaker bar soak it with monkey piss first:D
