ABNTGR
- August 6, 2014
- Colorado
I have had an odd whirring noise appear after some services. I did a tranny pan drain and refill, so about 3 qts or so. I did not drop the pan, just drained it. I also changed the power steering fluid at the same time for what it’s worth. The noise seems to be from underneath, increases with engine RPM then seems to go away after getting to temp. Any thoughts? Anything to worry about? This tranny is one that has the known whistling noise that now seems to be replaced with the new noise.
Should I do a full fluid exchange and see what happens?
2009 XLT V6, 149k.
Thanks. I did do a search but didn’t find anything that seemed to match
2009 XLT V6, 149k.
