who makes a 31" tire for a 17" wheel? | Page 2 | Ford Explorer Forums - Serious Explorations
i've looked (though, admittedly, not too hard) and i cant seem to find anyone that makes a 31" tire for my 17" wheels. i'm looking for a 31x10.5. ideally, i would love to get some bfg a/t ko's, but they dont make what i want. the closest thing i can find is a 265 70r17 which is NOT what i'm looking for. 31's are already gonna be a tight fit on my truck, and the 265 70 r17's are a little bigger than 31's and i dont wanna deal with trimming too much.
those birdgestone a/t revos are pretty nice too, but ill check out any suggestions at this point. (i'm not planning on buying anything until the spring, but i wanna be prepared for when i get my tax return :D )
TIA
guys, i'm still lost. i was looking at 17'' bullit rims, and i'm wondering what the biggest possible tire i could get on there was without trimming. i don't want a street, lowered look, i just want a gap filling tire on the bullits.
how do your 31s clear now?
perfect. i didn't have to trim and no rubbing at all. and they fill the gap between the tires and fenders nicely. i basically want he same look and height that i have now with my stock 15'' teardrops and 31's, just with 17'' rims and whatever size tires that would fit without rubbing or major trimming.
A 31" tire will be taller on a 17" rim then on a 15" rim. For istance, my 35s are truely 35" tall when on the truck. The same tire on a 15" rim will usually come out to being around 33" tall, all said and done. Just an FYI. If you find a metric size that's 31.5-32" tall, then you should be good to go.
do you think a 265/70/17 would fit without rubbing?
it converts to:
diameter: 31.6 section width: 10.4 section height: 7.3
That will ultimately depend on the back spacing of the wheels. The bullit rims have quite a bit of positive offset. You may need spacers to get the rims and tires out just a bit to the edge of the fenders. I cannot remember but I'm thinking it'll be close.
yep, i was thinking the same thing.
Originally posted by nole99
..... the tires fit rather nice I only had to trim the lower backside of my running board that sticks out in a wierd fashion. No prob thouhg as it was the backside and I just cut along the contour of the board to match the curve of the fender.
This most likley won't be a prob as you have a sport. My TT gave me about 1.5 inches.
Mounted on the 17 X 8 the tire measures 31.1 x 10.3
My wheels have around 4.7 inches of backspace so the tire sticks out about an inch and a half over stock.
I rub on the sway bar slightly at full lock.
I will have some pics this weekend so hopefully I figure out how to get them up
That was measurements on a 265/70/17
I have a pic of what I cut if I only knew how to link it.
Basically you cannot even tell where I cut the board. It is on the lower inside or teh front of running board, there is a part that sticks out like a fang took about 2 minutes and a shear scissors to cut off as it is just plastic.
Here are the pics ... hope they work
inside the red box is the part of the running board I trimmed, I will go bach and eliminate about another half inch and clean her up
Flash distorted this a bit but it'll do
Full view
need pics from another angle let me know
Edit to add:
These AT REVO tires absolutly rock!!!! Quiet ans Quiet gets, handled phenominal in the foot of snow we got the other day when the roads were plowed for sh*& becasue it was coming down so fast. It tried to get them to slide and slip and had very little luck slamming on the brakes from 45 yielded no anti-lock action, felt very much in control @ 50-60 on the highway in the snow and slush...prolly could have gone faster but didn't want to push it. No problems at intersections that were slippery as hell with others sliding around
Note the speeds driven were for test purposes not what I would normally drive.
The best part is they cost $580 for 4, only proble was I had to have them rebalanced ... darn tech
Hope this gives an Idea
nole, those are 265/70/17 right? but you have shackles too right? i'm wondering if they would fit on bullet rims on my X without shackles. i can do a TT no problem, but i don't really want to put shackles on. thanks.
Yes they are 265 70 17. I did shackles and an AAL, to level out the TT. If you jsut do a TT your front will be higher than the rear. The shackles and AAL cost $80 and about 2.5 hours to install. My rear end was saggy so wanted it up so I went with teh shackle and AAL.
I will take a pic of my clearance with my wheels turned and post back to give you a better idea. You might get away with no TT. Now that I am done tweeking mine it has settled and been leveled out; I ended up with an inch of TT up front.
