badge49
- September 8, 2005
- Humboldt, CA
- '97 XLT 4X4
Yesterday I decided to make a spiffy little bracket to cover my coil pack, as the clips on the spark plug wires are breaking off. The idea was to make a cover bracket that would better secure the plugs to the coil and prevent misfires by loose plugs. Take a look at my picture to see what it looks like:
Here's my problem: After bolting the new cover bracket on, I started the engine and it ran poorly. I turned off the engine and unbolted the two closest corners of the new bracket to releive the pressure holding the plugs down. I started the truck and it ran normally. With the engine idling, I reached my hand between the plugs and the new bracket (angled-up, still grounded)...and Ka-Pow! I got one hellova shock up my arm!
My theory is that with the engine running, there was enough power at the coil/plug seats to arc to the grounded metal plate. With the bracket pressing down on all six plugs, they misfired. When I reached in-between the bracket and coil, my hand acted as a short circuit.
My question is: How was the shock able to penetrate through the insullation of the plug wire? I've touched the plug connections before, with the engine running, and not been shocked. I'm going to play with this more and add a few layers of rubber under the bracket. Note to self: Don't reach in there again with the engine running...my arm still feels a little sore!:navajo:
