- January 11, 2001
- McVeytown, PA
- '18 XLT
Originally posted by rvitek
The 4.6L Northstar has 27K miles on it running 0W30 oil.
The 5.0L XLT has 47K miles on it running the same, 0W30 oil.
As a test, I'm going to switch back to GM/Ford-recomended oil-weights and dino oil on the next change to see what kind of consumption I get.
Ry.
That's what I was going to recommend. An 0 weight oil is very thin and may be seeping by the seals. I know people run it for better mileage, but the engines have tolerances built into them that are designed for a specific oil weight. Exceed that spec on either side and it can cause problems. Too thin and you get excessive consumption and you can cause premature bearing wear (the oil fills the space in between the bearings and the crankshaft, which is usually in the 0.002" to 0.004" range), too thick and you might not get enough lubrication to critical components. I don't think you need to go back to dino, but I definitely would suggest using the factory specified weights.
