:smoke:Yes the newer rims will fit your 91-94 Explorer. The bolt pattern stayed the same. I think that some of the explorers went from a 15 inch rim to a 16 inch rim so check that if you plan on using your same tires.
Brian is correct that they will fit, but for the front tires wheels caps, you will probably have to drill out the center to make room for your hubs. Figured I would throw that in for you!
I am thinking of asking my friend if I can "Borrow" his wheels from his '99 for 1/2 day. I want to determine if my shake is from the tires or the drive train. I can do that without the center caps
