Will I need an alignment after lowering blocks? | Ford Explorer Forums
ornithology
Vancouver, BC
'03 X Sport2dr 4.0 V6 XLT
If I put a 1.5" lowering block in the rear of my truck will I need an alignment?
From my understanding only the front can be aligned not the back of the 03 Sports right?
You are right. The rear is a solid axle and wont have any sort of Camber/Caster adjustment. You would only need an alignment after lowering your front.
Sweet. Thanks.
umm, lowering the rear will change the caster angle.
Just the act of adding a few hundred pounds to the rear will have an effect on the front alignment
