Also what are the stock dimensions of Explorer wheels?
I had to go to the Canadian Ford site to get the wheel sizes. For some reason I couldn't find that info on Ford.com.
The Boss has 245/35WR19 fronts and 285/35WR19's on the rear. When comapring these sizes against the Base (245/65R17), XLT (245/60R18) and Limited (255/50R20) the tire calculator says these (mustang) tires should not be used because the diameter difference far exceeds the max recommended of 3%.
Unfortunately I do not know the exact specs of the wheels. Your local dealer's parts department may be able to help there. Ford doesn't seem to release this info readily.
They'll fit however the backspacing is the problem cause if I recall its in the neighborhood of like 6 inches or so.. Maximum amount of backspacing a Explorer could work with is 4 to 4.5 inches.
