Will my wheels fit my friends X?? | Ford Explorer Forums
BradleyBT
NE
2000 XLT
They are a 15X8 w/ 4.5bs and and a 31X10.5 BFG
I have looked around and the tires will fit but the back spacing is a concern.. I think he has a 2000 X
All the Explorer wheels are interchangeable. Model and year doesn't matter.
Welcome to the site!
Like Jeff said all Explorers have the same bolt pattern. However, the stock backspacing is 4.5, so 4.5 8" wide's might rub a little on the inside (stock wheels are 7" wide). But you shouldn't have much of a problem, especially if the other X has 2" of lift.
What is the easiest way for him to get the 2"?
Thanks for the welcome!!!
If he has a 2000, then the Torsion Twist and Warrior Shackles is the easiest way. You will probably need an alignment afterwards though. Do a search on Torsion or TT or Warrior and you will find tons of info. Quite a few of us are running this setup. It's cheap and easy :p (Just the way I like it :D ). Costs about $50 + an alignment and only takes an hour or two if you have a socket set and are handy with a wrench.
