Will they work? | Ford Explorer Forums
Will they work?
ammo troop
Perry County Ahia (Ohio)
1993 "BAD"Sport"
Need some advice from the masses, My 93 is lifted 2 1/2 in. (suspension) want to see if I can go up to a 32x11.50 15 on stock rims without rubbing, Also how did it affect your gearing/takeoff? Need some advice before I lay down the cash... Thinking of maybe a body lift of 2" just in case
If ya ain't been stuck..ya ain't been wheelin!
with a 2.5" suspension lift 32's on stock or 15x8's will fit. with a 2" body lift 33's won't be a problem. Robbie
ammo troop,
They will fit either way but if you do any fourwheel then you should go with the body lift so you have some tire travel. But if you only want the look then it really does matter.
