will this work for my sas? | Ford Explorer Forums
Not unless you run a different transfer case that will make you passenger side drop (you're currently Driver side drop)
Yes, it's full width, so you'll need to space out the coil buckets if you buy that one and run coils. If you run leafs, that's a different story. Most of the axle swaps are done with 77-79 F150/78-79 Bronco axles (coil sprung setups). Most of the leaf sprung setups use a Jeep Wagoneer front Dana 44 (newer than the one you listed so it's DSD)
yup However if it did come from a 78 it will have cast wedges on the axle tubes. May or may not be a problem depending on how you setup your suspension.
the off set rear will do no good for you ane would probably be a step backwards in strength compared to an explorer 8.8 The vacume disconnect for the front axle copuld be a problem. I cant tell from the pictures.
This thread should be in the offroad drivelines section just FYI.
